CVP VXML Server encountered a No Session error
Oct 31st, 2008
Config:
CVP Call Server 4.02
CVP VXML Server 4.02
ICM 7.2.3
Comprehensive Call Flow
Hi:
I deployed a test application from VXML Studio, the app simple plays an audio.
When I invoke the application from the ICM Script, it plays :
"I'm sorry, there was a problem with this application. Please call back later. Thank you."
The log in the CVP Server says:
Oct 31 2008 10:41:11.203 -0300: %CVP_4_0_IVR-3-CALL_ERROR: CALLGUID=770CC403-A69311DD-8909BADF-12D5E68D DNIS=91994 CVP VXML Server encountered a No Session error - URL: http://192.168.31.50:7000/CVP/en-us/../Server?callid=0&application=HelloWorldFromICM (Client: 192.168.31.10) [id:3023]
30: 192.168.31.50: Oct 31 2008 10:41:11.203 -0300: %CVP_4_0_IVR-3-CALL_ERROR: RunScript Error from 192.168.31.10 [CVP_NO_SESSION_ERROR(44)] CALLGUID: 770CC403-A69311DD-8909BADF-12D5E68D DNIS=91994 {VRUScriptName: 'GS,Server,V' ConfigParam: ''} [id:3023]
Who has to give to the CVP VXML Server the Session ID parameter?
thank you in advance
marcelo
Ritesh Desai Mon, 08/24/2015 - 03:39
Hey rolecram1960,
I faced the same problem. The error causing this was because of wrong URL defined in ICM Script. Correct one is:
http://VXMLIPAddress:7000/CVP/Server?application=HelloWorldFromICM
So in ICM Script Editor config goes like this;
Set Variable Media Server = "http://VXMLIPAddress:7000/CVP"
Set variable Media Library = ".."
Set Variable ToExternalVXML = "application=HelloWorldFromICM"
regards,
Ritesh Desai
Please rate if helpfull
