Using IP Communicator with IPCC Express
Oct 31st, 2008
I'm trying to setup IP Communicator for use with IPCC Express. The issue I'm having is when the agents try to log in using the IP Communicator they can log in but when they select to make themselvs ready they are getting a message saying requesting and then it eventually times out with host not found message. Any suggestions.
Kenneth Mohammed Fri, 10/31/2008 - 08:44
  • Silver, 250 points or more
You have to associate the device name (mac address) you are using for your ip communicator with the rm user for ipcc in the global directory. Also be sure that the same device is associated with your user id in global directory. Otherwise, you will not be able to change ready states in Agent Desktop.
Hope that helped, if so please rate.
