Rob Huffman Fri, 10/31/2008 - 10:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi James,
Likely you need to Stop/Start the TCD Service :)
Q. Why do line states of some directory numbers show unknown state?
A. Telephony Call Dispatcher (TCD) service is not started on all Cisco CallManager servers that have phones homed in. Start TCD services on all CallManager servers that have phones homed in. If this is an upgrade, make sure that you upgrade the TCD server on all Cisco CallManager servers in the cluster.
Hope this helps!
Rob
Rob Huffman Fri, 10/31/2008 - 12:48
  • Hall of Fame,
    Founding Member
Hi James,
Sorry man! That reference is for CCM 4.x versions and I think that you may be running CCM 6.x. Try this instead;
Go to Cisco Unified Serviceablity
Go to Tools>Control Centre - Feature Services>Attendant Console Server Service
Hope this helps!
Rob
Rob Huffman Tue, 11/04/2008 - 07:29
  • Hall of Fame,
    Founding Member
Hi James,
Good stuff my friend! Glad to hear that you got things working properly. Sorry for the bad info on the first post.
Cheers!
Rob
thumptech9 Thu, 11/06/2008 - 10:28
If i add a new phone to call manager for a new department and i get status unknown (?)the following day that status unknown issue is no longer (everything is fine). Does a process update status of phones at timed intervals ?
Rob Huffman Sat, 11/08/2008 - 08:09
  • Hall of Fame,
    Founding Member
Hi Kevin,
The Directory Window is not quite "real-time" as you have discovered. There are a couple of ways that the Directory is updated, the one that happened here is probably the Directory Sync Period . Have a look;
The attendant console server reads and caches directory entries at startup. After an initial handshake determines whether the directory entries changed since the previous log in, the attendant console downloads the directory user list. The attendant console also downloads the user list when the interval in the Directory Reload Interval field in the Attendant Settings dialog box expires or when the user clicks the **Reload button in the Directory window.
AutoGenerated.txt file that is generated by the Cisco TCD service and stored in the userlist directory on the Cisco CallManager Attendant Console server. If the Directory Sync Period service parameter does not equal zero, Cisco TCD generates the AutoGenerated.txt file when the Cisco TCD service starts and when the directory sync period expires.
To modify the Directory Sync Period service parameter, choose Service > Service Parameters. Choose the appropriate server from the Server drop-down list box and choose the Cisco Telephony Call Dispatcher Service from the Service drop-down list box.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803f3a8b.html#wp1144934
Hope this helps!
Rob
