10-31-2008 09:00 AM - edited 03-15-2019 02:17 PM
is there a command to look at channels that are busy and is there a command under the ios to take them of busy
Solved! Go to Solution.
10-31-2008 09:05 AM
Im not sure if there is a command to reset individual channels, but you can bounce the PRI as a whole by doing a shut/no shut on controller t1 x/x/x, voice-port x/x/x:23, and interface serial x/x/x:23.
Hope that helped, if so please rate.
10-31-2008 09:02 AM
If you issue a "show isdn service", it will show you the status of the channels of your PRI.
10-31-2008 09:03 AM
thanks is there a command to reset a channels
10-31-2008 09:05 AM
10-31-2008 01:52 PM
You can do this in Call Manager -
