Warning message
Recommend Two EIGRP AS or one EIGRP AS on ASA 5520?
Oct 31st, 2008
A network with an edge branch with a dmz and inside network with HQ with the same two DMZ and inside networks. Must I have two EIGRP AS, one for the outside and one for the inside and dmz, on an ASA 5520 acting as the next hop before an edge router at the branch? Is there an issue/technical limitation of the ASA line with having one EIGRP AS?
Anonymous (not verified) Thu, 11/06/2008 - 08:52
There will not be any issue if you configure EIGRP for single AS. EIGRP is supported with ASA having software version of 8.0 and later.
