netconfig devicefile invalid argument
Answered Question
Oct 31st, 2008
I use LMS 3.1
I run exactly the same command but I get th following message:
cwcli netconfig createjob -u admin -p password -devicefile /opt/CSCOpx/bin/test.list -commandfile command.file -policyfile policy.in -description "cwcli netconfig job" -mode config
<cwcli> FATAL - NETCLI014:Netconfig createjob command failed
<cwcli> FATAL - Invalid argument: officeuk
my test.list file content is:
cat test.list
officeuk
The weird thing is that if I run the same command but without having a file but device (-device officeuk), it works!
I can't see any reason why this is not working, can u?
what is the correct argument did i miss something? I read the netconfig's manual and it is said to enter devices name contained in RME database.
regards
alex
Correct Answer by Joe Clarke about 8 years 6 months ago
This is a bug in the documentation. The device file must be an extension of the regular CLI. So, the syntax is:
-device device1[,device2[,device3[,...]]]
In your case, this will work:
% cat test.list
-device officeuk
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 10/31/2008 - 11:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
% cat test.list
-device officeuk
durale1789 Mon, 11/03/2008 - 03:41
it worked! thank you very much
i guess if i have more then 1 device the file will contain something like that:
- device device1,device2,device3,etc...
regards
alex
