Multicast on 3750s
Answered Question
Oct 31st, 2008
I see that cgmp is not supported on Cat3750s. In other catalysts I just enabled cgmp to be sure that a multicast stream did not get forwarded to every port on the switch. What do I need to configure on the 3750 to accomplish the same end? I don't play on having any inter-vlan multicast. Just need to know how to control it within a single vlan. Thanks.
Correct Answer by Joseph W. Doherty about 8 years 8 months ago
Enable IGMP snooping (believe the 3750s support it).
Overall Rating: 5 (1 ratings)
Correct Answer
Joseph W. Doherty Fri, 10/31/2008 - 12:15
mmedwid Fri, 10/31/2008 - 12:34
(config)#ip igmp snooping
...looks to have done the job. Thank-you.
Vlan 22:
IGMP snooping : Enabled
IGMPv2 immediate leave : Disabled
Multicast router learning mode : pim-dvmrp
CGMP interoperability mode : IGMP_ONLY
Robustness variable : 2
Last member query count : 2
Last member query interval : 1000
