ACE Source NAT + inspect ftp
Oct 31st, 2008
Since upgrading to the A2 code from the 1.6.3 code you must apply inspect ftp on a layer 3 class.
This has broken my outbound NAT when using FTP, and I'm wondering what the workaround is. In A2, all of the 'inspect ftp' statemens below are invalid. But I also don't know how I would be able to match the servers on a layer 3 basis to get the inspect ftp command to accept inside the class??
Right now I'm stuck on 1.6.3, which has a serious bug that warrants upgrading, but I'm not sure how to get FTP inspection inside my NAT classes.
policy-map multi-match NAT-Policy
class DST-NAT-internal
nat dynamic 500 vlan 410
class DST-NAT-accuratenxg
nat dynamic 131 vlan 310
class DST-NAT-accurate1
nat dynamic 21 vlan 310
class DST-NAT-margin1p
nat dynamic 22 vlan 310
class DST-NAT-nuflowdb1p
nat dynamic 23 vlan 310
class DST-NAT-nuflowsch1
nat dynamic 24 vlan 310
class DST-NAT-nuflowweb
nat dynamic 25 vlan 310
class DST-NAT-reconapp1
nat dynamic 26 vlan 310
class DST-NAT-recondb1p
nat dynamic 27 vlan 310
class DST-NAT-clrdb1p
class DST-NAT-bsatech-ftp
nat dynamic 28 vlan 310
inspect ftp
class DST-NAT-bsaclearing-ftp
nat dynamic 30 vlan 310
inspect ftp
class DST-NAT-gloss1
nat dynamic 32 vlan 310
connection advanced-options TCP_Timeout_Sybase
class SRC-NAT-bpsadv1p
nat dynamic 33 vlan 310
class SRC-NAT-jedi1p
nat dynamic 34 vlan 310
inspect ftp
Gilles Dufour Tue, 11/04/2008 - 05:51
you should only apply the inspect ftp command to a class-map that matches x.x.x.x:21.
Do not apply it to anything else.
Make sure to run version A2(1.2)
CSCsr46740: FTP Inspect failing to fixup IP address in FTP PORT request
acennami Tue, 11/04/2008 - 06:38
OK, but how do I apply that on the outbound NAT, which is matched against a Layer 3 ACL?
(I also noted I could not create Layer 4 ACLs after upgrading)
Gilles Dufour Tue, 11/04/2008 - 06:45
You only need to inspect the control channel (normally port 21) on inbound.
Inspection should detect all your nating (inbound and outbound) and do the rest correctly.
It was broken in A2(1.0) and was fixed in A2(1.2).
