CVP Java Script
Oct 31st, 2008
So I am still a little new to CVP Studio so bear with me. In IPIVR you can call Java functions like String.substring(0,3) and it will return the first 3 characters of the string. How would you accomplish this in CVP Studio?
Chad Stachowicz Fri, 10/31/2008 - 17:31
  • Silver, 250 points or more
Well in CVP you actually need to write a custom Java class. There isn't builtin Java functions like there is in IP IVR. The documents on Java for CVP Are quiet extensive. You will then use things like the action element and the decision element to use the classes :)
HTH,
Chad
Chuck Smith Fri, 10/31/2008 - 18:36
Which documents would you say are the best for starting with the custom classes. I am no where a Java developer so it might be a lost cause but I have gotten lucky from time to time. :)
Chad Stachowicz Sun, 11/02/2008 - 01:15
well on the devolpers forum / wiki thing. There is a bunch of CVP example class templates. After that its just knowing where to put the classes and thats all in the CVP Developers guide.
Chad
