%SYS-2-INTSCHED
sbilgi Thu, 11/06/2008 - 09:33
  • Silver, 250 points or more
Generally you will get this error when you are upgrading the IOS on Cisco 2851 router because it is failing to copy an IOS image can be attributed to a bad or corrupt flash disk. Try the bug id CSCsb42671& CSCsa54996. To fix this bug, I would recommend that you upgrade to the latest of the 12.3(11)T release which is 12.3(11)T8.
