LMS 3.1 Hum 1.1
Nov 1st, 2008
I have upgrade to HUM 1.1 and now my reports are not returning with collected data.
quick reports are fine, but my monthly reports only contain information up to the upgrade and nothing after.
And one ssen this issue ?
Joe Clarke Sat, 11/01/2008 - 08:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It sounds like there may be a problem with the summarization process. The upm_summarizer.log may show some errors.
Ian Beck Sat, 11/01/2008 - 11:32
There are now entries in the file since the upgrade !
Joe Clarke Sun, 11/02/2008 - 06:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I assume you mean there are no new entries after the upgrade. It sounds like the summarizer job may not be running at all. Go to Common Services > Server > Admin > Job Browser, and check on the state of the SUMMARIZER_JOB.
Ian Beck Sun, 11/02/2008 - 13:14
Yes last line is the 25 Oct.
You are right, the S_Job has not run since the 25 Oct, which is when reporting has stopped.
The question is how to recreate and get running.
Joe Clarke Sun, 11/02/2008 - 13:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can delete this job, then restart CiscoWorks Daemon Manager. The job will be recreated automatically.
Ian Beck Mon, 11/03/2008 - 00:17
Hi, Many thanks for your help that's seems to have fixed it although I seem to have lost definition to the data for the period it was not running, but not an issue.
Where is this documented ?
Joe Clarke Mon, 11/03/2008 - 09:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It is not documented, and should not have been required. Something must have gone wrong in the upgrade.
