Clientless SSL VPN help
Nov 1st, 2008
I have a couple of questions I hope someone can answer about clientless SSL which I have enabled on my ASA 5520.
1.) I can login using https://asaiip but I don't think I am using a certificate as there is a setting on the ASDM that says on the outside interface "requires client certificate" if I tick this it says the ASDM is also using port 443 and something about it will enable certs for the ASDM too is this ok?
2.) I have created 2 aliases (IT and users) so when I go to https://asaip it has the logon page and then a drop down box with both aliases, my big problem is that users can get into either alias.
I need corp users to only be able to access "users" and not "IT" how can I do this? I am using a windows RADIUS server (IAS) to allow users in.
