configuring ASA for PortForward SMTP to DMZ
Nov 1st, 2008
I'm new to ASA.
Need some help to config the ASA Firewall. I'll be installing an antispam in the DMZ and a new Mail Server in the Tusted. As such, need to forward port 25 from the External IP to the DMZ's AntiSpam IP plus to allow port 25 from DMZ to Internal.
Please advise on how I can do this.
Thanks & regards,
abinjola Sat, 11/01/2008 - 04:32
for inbound traffic from outside to dmz
static (dmz,outside) tcp 25 25
access-l outside_acl permit tcp any host 25
access-g outside_acl in interface outside
For communication between dmz and inside
static (inside,dmz)
private ip-->ip address of internal exchange server
access_list dmz_acl permit tcp any host eq 25
tmssupport Sat, 11/01/2008 - 15:51
Thanks for the reply. Will try this.
By the way, we have a Active-Passive ASA cluster. By changing the above on the Active unit, will the change be automatically added to the Passive unit ?
regards,
abinjola Sat, 11/01/2008 - 20:44
yes..do a write standby and it will be copied and saved on the other standby unit
Do rate if it helps !
