NM-16ESW as a hub
Nov 1st, 2008
Cisco 2651XM router with
NM-16ESW 16 port switch
is there any way to configure the NM-16ESW switch to act as a plain hub? I've only had the 16port switch for a short while and I've managed to get it working by creating a VLAN and assigning an ip address to it (thanks to allans help), but I also wanted a method where I could just use it as a hub - to act as an extension of either port f0/0 or f0/1.
Thanks for any advice.
Overall Rating: 4 (2 ratings)
ohassairi Sun, 11/02/2008 - 01:14
  • Silver, 250 points or more
hi tony
i did not understand why you need to convert your switch to a hub. if you need to monitor some traffic in one port, you can use SPAN (switch port analyzer) feature
tonyspcrepairs Tue, 11/04/2008 - 12:41
yes you're right, my question was borne out of the fact I didn't understand this switch properly but now I'm getting better at it I can see how to configure it.
andrew.butterworth Sun, 11/02/2008 - 08:07
  • Gold, 750 points or more
I assume you mean 'switch' as opposed to 'hub'? If that's the case then I think you could do this with bridging:
bridge 1 protocol ieee
interface FastEthernet0/0
bridge-group 1
interface FastEthernet 1/1 ! not sure how the ports on a NM-16ESW appear?
switchport access vlan 10
interface vlan 10
bridge-group 1
interface bvi 1
ip address 10.1.1.1 255.255.255.0
I am not sure why you would want to do this though as you could simple not use the 'regular' fa0/0 interface and just use the ports on the NM-16ESW?
Andy
tonyspcrepairs Tue, 11/04/2008 - 12:42
thanks for your response Andy, I didn't know about bridging but I will try the config you have given above. Cheers.
