DHCP option 82 in WLC526
Nov 1st, 2008
I needed to use DHCP option 82 in my wireless network, but I can't enable this option on WLC526. DHCP proxy enable, auto-anchor mobility is not supported. But I still have in show run-config this:
DHCP Option 82..................Disabled
Could you advise me anything?
owillins Thu, 11/06/2008 - 19:39
Please reconfigure the Device.
config interface dhcp
To configure DHCP options on an interface, use the config interface dhcp command.
config interface dhcp {
ap-manager [primary dhcp_server secondary dhcp_server | option-82 [enable | disable] ] |
management [primary dhcp_server secondary dhcp_server | option-82 [enable | disable] ] |
service-port {enable | disable} |
interface-name name [primary dhcp_server secondary dhcp_server | option-82 [enable | disable] ]}
Examples
> config interface dhcp ap-manager server-1 10.21.15.01 server-2 10.21.15.25
> config interface dhcp ap-manager option-82 enable
> config interface dhcp service-port enable
tsarycheva Thu, 11/06/2008 - 21:40
Thank you for the answer.
Unfortunately I haven't this command in WLC526's CLI. I suppose that reason following:
"The WLC526 controller is simple to install and operate; therefore, the controller CLI consists of a limited number of primarily show and debug commands." (extract from Cisco 500 Series Wireless Express Mobility
Controller Configuration Guide).
These commands available:
(Cisco Controller) > config ?
advanced Advanced Configuration.
(Cisco Controller) >config advanced ?
802.11a 802.11a parameters.
802.11b 802.11b parameters.
client-handoff Auto handoff the clients on excessive retires.
dot11-padding Configure over-the-air frame padding
eap EAP (Extensible Authentication Protocol) Settings
macfiltering Configure advanced macfilter settings.
max-1x-sessions Maximum 802.1x session initiation per AP at a time.
probe-limit Limit number of probes sent to switch per AP slot per client in a given interval.
rate Enable/Disable switch control path rate limiting.
statistics Enable/Disable switch port statistics.
timers Configures system timers.
Mini IOS Version.............................3.0.51.0
IOS Version...........................12.4(10b)JX
