11-01-2008 06:55 AM - edited 03-06-2019 02:15 AM
How can i set all the settings back to factory default? The Express Setup and Resetting the Switch do not do the job. What is the way?
TIA
Solved! Go to Solution.
11-01-2008 08:05 AM
Telnet or console into the switch and enter 'enable' and the password (if any). Then type following commands:
switch#write erase
Erasing the nvram filesystem will remove all configuration files! Continue? [con
firm]y
switch#delete flash:/vlan.dat
Delete filename [vlan.dat]? y
Delete flash:n? [confirm]y
Then either type reload or power reset the switch and it should reboot at factory default. If the config register has been changed or any parameters changed from ROMMON then you would need to correct these as well.
Andy
11-01-2008 09:44 AM
I haven't got a 3750 to hand but I think this should work:
Type 'show switch' and determine the switch's number (that it used to be in the stack). Then renumber it using the command 'switch x renumber 1'. Then reload the switch.
As for the VLANs remaining I thought removing the VLAN.DAT file would solve this, however it may be different with 3750 stacks.
Andy
11-01-2008 07:10 AM
Hello Mark,
if you want to have the switch ignore the configuration file
access the switch via telnet
get enabled mode
switch#
config t
config-register
! the right value can be found looking
! for the password recovery procedure
exit
write mem
reload
if you want to delete the config with no chance to recover it
telnet to the switch
Switch# erase nvram:
Hope to help
Giuseppe
11-01-2008 08:05 AM
switch#write erase
firm]y
Andy
11-01-2008 09:07 AM
Thank you very much. there still has some left over,
vtp domain zad
vlan 10
name servers
vlan 20
name workstations
and also, this switch used to be a member of stack (not master), and till now, the interface is still showing as
interface FastEthernet2/0/1
interface FastEthernet2/0/2
interface FastEthernet2/0/3
as if it still is a member of stack. Anyway to return it back?
11-01-2008 09:44 AM
Andy
11-01-2008 05:27 PM
Thanks Andy. It worked. I ran the switch renumber, and ran no service password-recovery to see if vlans were removed, and it was not. So ran those commands again as you suggested:
switch#write erase
firm]y
! did not type y here. I did it last time, and got ânot foundâ error. That probably explained why.
And ran reload, everything is back to default.
Thanks again
11-03-2008 06:00 AM
As a side option, try pressing down the mode button until all the status lights above the mode button light up and then extinguish. You should hear the fans spin up for a second as the unit reboots. If you have the console on screen, you should see a message appear saying the config has been reset and the switch will be restarted.
Quickest way I've found to do a reset (though after finding out about it, I'm more concerned about physical security now with the switches).
