SSL VPN client
Nov 1st, 2008
I'm using SSL clientless VPN mode on my ASA, but have just read that there is a SSL client aswell, how does this differ, plus how can I set this up as I assume a user can connect over the internet through their web browser and somehow download this client and use it to VPN in?
purohit_810 Sat, 11/01/2008 - 12:50
See Cisco Has following VPN solutions for remote access:
1) SSL VPN
2) IPSec client
SSL VPN:
1) Clientless: Clientless mean, you are advertising org. resourses by one portal.SSL VPN portal creates SSL socket and encrypts traffic by certificates. It is secure. More over you can access your organization workstation , servers, and network devices by RDP (Plugins), VNC (Plugin) and telnet and SSH.
2) SSL Client: Cisco has just lauched Anyconnect client. Anyconnect client has buety of it starts to download and install from clientless vpn portal and it wipe up automatically from the client the client upon session disconnection. Second full/partial access of corporate network.
3) IPSec client it has Client software needed, on public machine like cybercafe or startbucks internet access.. where gonna they will have IPSec client installled? second they will have need specific settings?
Dharmesh Purohit
jamesgonzo Sat, 11/01/2008 - 13:32
1.) I've managed to get the VNC, RDP plugins to work fine, but I'm having problems with the Citrix ICA plugin, have you used this before?
2.) How can I configure Anyconnect? Is it a better solution to Clientless in your opinion?
3.) On cliientless connection I haven't enabled the "client requires certificate" on the outside interface, do I need to enable this?
A huge thanks
