NAT causes duplicate I.P
Answered Question
Nov 1st, 2008
I have a strange problem. We have nat setup on our gig 0/0 interface. You would think that it wouldn't create an arp entry for the natted I.P since its being done inside. However, it seems that for some reason, the nat I.P we are using is being advertise between both routers and they are complaining about duplicate I.P. Is this a bug? Not sure how to resolve this issue.
thx.
Here are some of the outputs I'm seeing.
il400s02hwr02#show version
Cisco IOS Software, 3800 Software (C3845-ADVIPSERVICESK9-M), Version 12.4(8c), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 12-Dec-06 02:09 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
il400s02hwr02 uptime is 36 weeks, 6 days, 47 minutes
System restarted at 08:47:27 EST Sun Feb 17 2008
System image file is "flash:c3845-advipservicesk9-mz.124-8c.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3845 (revision 1.0) with 484352K/39936K bytes of memory.
Processor board ID FTX1133A3UZ
2 Gigabit Ethernet interfaces
1 Serial interface
1 Virtual Private Network (VPN) Module
1 Subrate T3/E3 port
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
125440K bytes of ATA System CompactFlash (Read/Write)
Nov 1 10:40:37.798 EST: %IP-4-DUPADDR: Duplicate address 10.154.31.47 on GigabitEthernet0/0, sourced by 001d.46c7.8250
Nov 1 10:41:07.799 EST: %IP-4-DUPADDR: Duplicate address 10.154.31.93 on GigabitEthernet0/0, sourced by 001d.46c7.8250
Nov 1 10:41:37.800 EST: %IP-4-DUPADDR: Duplicate address 10.154.31.25 on GigabitEthernet0/0, sourced by 001d.46c7.8250
Nov 1 10:42:07.800 EST: %IP-4-DUPADDR: Duplicate address 10.154.31.71 on GigabitEthernet0/0, sourced by 001d.46c7.8250
Nov 1 10:42:37.801 EST: %IP-4-DUPADDR: Duplicate address 10.154.31.8 on GigabitEthernet0/0, sourced by 001d.46c7.8250
il400s02hwr02#
il400s02hwr02#show running-config interface gigabitEthernet 0/0
Building configuration...
Current configuration : 268 bytes
interface GigabitEthernet0/0
description CBOE_RTR1
ip address 10.154.31.2 255.255.255.0 secondary
ip address 192.168.86.168 255.255.255.240
ip access-group 100 in
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
media-type rj45
no keepalive
end
ip nat inside source static 170.137.48.32 10.154.31.5
Correct Answer by Giuseppe Larosa about 8 years 8 months ago
Hello Bedevere,
have you configured stateful NAT on the two C3845 ?
see
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iadnat_cfg_ha_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1053349
This can be helpful
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
bedevere.curry Wed, 11/05/2008 - 10:32
Thanks. We will try it this weekend since we can't make any changes to it during the weekday.
