VLAN setup with c3750
Answered Question
Nov 1st, 2008
Hi All,
I am new with VLAN, and need help. I have read previous post but cannot solve all my needs, so here is the question. The network diagram is as attached. VLAN 1 will be those Windows 2003 DC and DHCP, DNS.
VLAN 2, and 3 are workstations.
All workstations in VLAN 2 and 3 can get IP address, DNS service, and file service from DC in VLAN1, and access Internet through Firewall Proxy in VLAN1.
TIA
Correct Answer by Jon Marshall about 8 years 4 months ago
3750(config)# ip routing
3750(config)# vlan 2
3750(config-vlan)# name vlan2
3750(config)# vlan 3
3750(config-vlan)# name vlan3
3750(config)# int vlan 1
3750(config-if)# ip address 192.168.16.1 255.255.240.0
3750(config)# int vlan 2
3750(config-if)# ip address 192.168.32.1 255.255.240.0
3750(config-if)# ip helper-address
3750(config-if)# no shut
3750(config)# int vlan 3
3750(config-if)# ip address 192.168.48.1 255.255.240.0
Then you need to assign ports into vlans so for example PC on port gi1/0 you want in vlan 2
int gi1/0
switchport access vlan 2
Each server/PC's defaul-gateway will be it's respective IP address on the L3 vlan interface you configured above.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Sat, 11/01/2008 - 08:19
int gi1/0
Jon
markxgzhang Sat, 11/01/2008 - 16:19
Jo, The configure is done, but tried to connect a client on VLAN2, and it cannot get an IP from DHCP. And also, cannot ping 192.168.32.1 when client is physically attached to VLAN1. Attached DHCP snapshot. Does trunk need here for a single switch? Here is the run list
Current configuration : 1700 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
switch 2 provision ws-c3750-24ts
system mtu routing 1500
vtp domain zad
vtp mode transparent
ip subnet-zero
ip routing
! no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 2
name vlan2
vlan 3
name vlan3
vlan 10
name servers
vlan 20
name workstations
interface FastEthernet2/0/1
interface FastEthernet2/0/2
interface FastEthernet2/0/3
interface FastEthernet2/0/12
interface FastEthernet2/0/13
switchport mode access
interface FastEthernet2/0/24
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface Vlan1
interface Vlan2
ip helper-address 192.168.16.2
interface Vlan3
ip classless
ip http server
control-plane
line con 0
line vty 0 4
interface Vlan2
interface Vlan3
ip classless
ip http server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
End
Try to ping
Switch#ping 192.168.32.1
Sending 5, 100-byte ICMP Echos to 192.168.32.1, timeout is 2 seconds:
Success rate is 0 percent (0/5
Jon Marshall Sun, 11/02/2008 - 04:04
Mark
Can you
1) Leave the DHCP/DNS server in vlan 1
2) Attach your client to a port allocated into vlan 2
3) Hardcode an IP address from the vlan 2 range on your client and then try
i) ping 192.168.32.1
ii) ping 192.168.16.2
Let me know results.
Edit - after doing the above could you also post the output of
"sh vlan"
"sh ip int brief"
Note that your L3 vlan interfaces will only show up/up if you have an active port in that vlan so you will not be able to ping 192.168.32.1 if you don't have a client up and running allocated into that vlan.
Jon
markxgzhang Sun, 11/02/2008 - 13:08
Hi Jon,
Actually I found where the problem is. It is all coming back to basics. The DHCP box's default gateway was pointing to somewhere else instead of the default gateway of the vlan. After I changed to the gateway of the vlan, DHCP is working. Devices from different VLAN can get IP address, and access things across VLANs.
thank you very much.
markxgzhang Sun, 11/02/2008 - 20:56
Thanks Jon.
There is another question from this dummy guy. If I want to route traffic out of VLANs to access Internet through a firewall, do I need a routed-port on the switch as a representitive of VLANs? How to extablish this relationship between the routed-port and VLANs? What should I do to achieve this?
Jon Marshall Mon, 11/03/2008 - 00:36
Mark
Glad you got it working and no problem with further questions, that's what NetPro is for :-)
Is the firewall connected to the 3750 switch ?
You don't necessarily need a routed port, you could just use another vlan. It really depends on where the firewall is in relation to your addressing.
What you would need is a default-route on your 3750 pointing to the internal interface of your firewall ie.
ip route 0.0.0.0 0.0.0.0
then on the firewall you would need to add routes for the vlans on the 3750 switch. The next-hop would either be a vlan interface on the 3750 or as you say it could be a routed port.
If you could let me know whether the firewall is in one of your existing vlans and where it is connected to i can be more specific.
Jon
markxgzhang Sun, 11/02/2008 - 00:22
Hi Jon,
Here is the command list
Switch(config)# int vlan 1
Switch(config-if)# ip address 192.168.16.1 255.255.240.0
Switch(config-if)# no shut
Switch(config)# int vlan 2
Switch(config-if)# ip address 192.168.32.1 255.255.240.0
Switch(config-if)# ip helper-address 192.168.16.2
Switch(config)# int vlan 3
Switch(config-if)# ip address 192.168.48.1 255.255.240.0
Switch(config)#int range fa1/0/7 - 12
Switch(config-if-range)#switchport access vlan 2
Switch(config-if-range)#switchport mode access
Switch(config)#int range fa1/0/13 - 18
Switch(config-if-range)#switchport access vlan 3
Test results as follow:
When I plug the Windows 2003 DC and DHCP server into one of the VLAN1 port, and plug one WinXP into another VLAN1 port, the WinXP can get ip address from the DHCP server, which is an address within the VLAN1 range.
When I plug the Windows 2003 DC and DHCP server into one of the VLAN1 port, and plug one WinXP into one of VLAN2 port, the WinXP CANNOT get IP address from the DHCP server.
When I plug the Windows 2003 DC and DHCP server into one of the VLAN2 port, and plug one WinXP into one of VLAN2 port, the WinXP CAN get an ip address, but it is an address from VLAN1 range. Either than that, everything is fine. But VLAN here realy does not have any meaning, does it?
Can anyone tell me how to fix this problem please?
ohassairi Sun, 11/02/2008 - 01:40
try to add this command under inetrface vlan 2, 3,..
Ip directed-broadcast
markxgzhang Sun, 11/02/2008 - 20:59
Thanks guys,
