ACE - Probe suggestion for CheckPoint Firewall ?
Nov 2nd, 2008
Hi to all,
Assume that inbound interface of FW1 side cable unplugged. In this scenario the probes are still up. Probes cannot detect this situation and fail over doesn't take place. As you can see it is impossible to detect cable tear down unless we have an IP address from different vlan. I have an idea about to solve this issue, I need to create a new vlan (for instance vlan 200) on the ACE_INSIDE. We will insert a static route on ACE_OUTSIDE. That static route will try to access vlan 200 via FW1 outside interface. Then we will be sure when the FW1 fails. Of course vice versa will be valid. We can use similar configuration for the FW0 too. According to the configuration that I have attached and my solution, can you give me a configuration example or do you have a better way to accomplish this task. I will be waiting for your suggestion or solution as soon as possible. I have little time to solve this. Thanks in advance.
Best Regards.
Note: Topology and all necessary configs are attached.
cisco24x7 Mon, 11/03/2008 - 06:59
I am not sure I am following what you're trying
to do here. Are you running Checkpoint
ClusterXL in Active/Active or Active/Standby
configuration? Either way, ClusterXL is smart
enough to know if the interface is "unplugged",
and that failover is automatically. You should
not even have to worry physical interface.
ClusterXL will take care of the failover.
What do you see when you perform "cphaprob
state" and "cphaprob -a if"?
If your firewall does not failover, then it
is not setup properly. Both the ACE_outside
and ACE_inside only care about ClusterXL
VIP IP and not the physical IP of the
checkpoint firewall.
ctopaloglu Wed, 11/05/2008 - 01:07
Thank you for your answer. They are active/active. But the checkpoints we are talking are not using cluster XL for failover. They are using third party (ACE) for the fail over also. So ACE has to know about firewalls with probe. They don't have VIP IPs.
cisco24x7 Wed, 11/05/2008 - 06:25
First of all, this is the FIRST time I've heard
someone is running Securreplatform NGx R65
in Active/Active WITHOUT ClusterXL. I could
be wrong, though unlikely, but that is not
possible. Take a look at the pair of Checkpoint
firewall NGx R65 Secureplatform in Active/Active
Unicast mode:
[[email protected]-lab2]# cphaprob state
Cluster Mode: Load Sharing (Unicast/SDF)
Number Unique Address Assigned Load State
1 30% Active (pivot)
2 (local) 70% Active
[[email protected]-lab2]# cphaprob -a if
Required interfaces: 4
Required secured interfaces: 1
eth0 UP non sync(non secured), broadcast
eth1 UP non sync(non secured), broadcast
eth7 UP non sync(non secured), broadcast
eth13 UP sync(secured), broadcast
Virtual cluster interfaces: 3
Again, I think it is NOT possible to run
Checkpoint in Active/Active mode without
ClusterXL. You may want to check the
configuration again. You can NOT have
active/active without VIP IPs.
