LMS 3.1 RME 4.2 VLAN Config fetch issue
Answered Question
Nov 2nd, 2008
Recently upgraded to LMS 3.1 (RME 4.2). Now getting quite a few devices with "partially successful" Config archive status. Error is "Command failed VLAN Config fetch is not supported using TFTP. Could not detect SSH protocols running on the device" Primary and Startup configs are collected ok, ceredentials have been checked, etc. Devices are switches and routers that do not have a vlan.dat file. Other devices that do have a vlan.dat are collecting ok. I have read of a possible bug relating to this issue. If this is a bug can you let me know the ID?
Correct Answer by Joe Clarke about 8 years 5 months ago
Yes, there is a bug related to this. The ID is CSCsq66458. It will be fixed in RME 4.3. I haven't produced a patch for 4.2 yet (only 4.1.1), but one could be created if you open a service request with TAC.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Sun, 11/02/2008 - 22:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
lekgotla perciv... Wed, 01/28/2009 - 09:35
Hi Clarke
I have the same issue with my new installation of LMS 3.1
Do i also need to log a TAC case for this?
Joe Clarke Wed, 01/28/2009 - 09:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes.
