EIGRP doesnot advertise some static routes
Nov 3rd, 2008
i have 3750 Switch connected by layer to another of same model but eigrp doesnot advertise some static routes although it does it for other neighbours
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 11/03/2008 - 01:53
As requested by Satish, please post
1) Configuration details
2) routing tables
3) An explanation of which statics work and which don't.
Are you redistributing statics into EIGRP ?
mmasood_mohd Mon, 11/03/2008 - 03:21
i have EDS Switch which have static route which is not advertised to Access Switch thats why i have to write a Static route, i dont know why only this route is not shown in Access Switch my routing table but have others.although i have it in my EDS Routing Table
attached is the configuration of both the 3750 Switches.
Jon Marshall Mon, 11/03/2008 - 03:26
Could you clarify. Are any of the static routes on EDS switch showing up in access switch routing table ?
You are not redistributing static routes into EIGRP on EDS switch so it wouldn't get to the access switch.
Apologies if i have misunderstood what you are asking.
mmasood_mohd Mon, 11/03/2008 - 03:30
yes if you see the routing table of access Switch you can find routes to and other static routes in EDS switch
ip route
ip route
ip route
ip route
ip route
ip route
ip route
ip route
gagamboy15 Tue, 11/11/2008 - 05:38
Hi Guys,
How can you configure EIGRP to advertise static route? Thanks in advance.
Jon Marshall Tue, 11/11/2008 - 05:42
Under your EIGRP configuration
router eigrp 1
redsitribute static
Note that you can use a route-map with the redistribuet static if you only want to advertise some of your statics.
gagamboy15 Tue, 11/11/2008 - 16:27
Hi Jon,
Thanks for the reply. Can you please give me a link on where I can study it more deeply? I am not sure If programming statement can also be applied to Network configs like for example:
If this packet came from this destination
then perform this operation.
