11-03-2008 02:06 AM - edited 03-09-2019 09:46 PM
We wanted to know if there is a way to disable âAggressive modeâ on the VPN concentrator.
For example, on the ASA, we can do it using the command âisakmp am-disableâ
On a router we can do it using the command âcrypto isakmp aggressive-mode disableâ.
Is there a similar command on the VPN concentrator ?
Your help is appriciated.
11-03-2008 04:10 AM
On the VPN Concentrator Web consolgo to this paage,
Configuration > Policy Management > Traffic Management > Security Associations
select the IPSec SA created for the particular VPN session, then Modify
Go under IKE Parameters and then change the Negotiation Mode.
Hope this Helps.
11-03-2008 05:27 AM
Thx, Does this prevent a vpn client from using aggressive mode. From the tests it seems that it still can access using aggressive mode (is it normal)? (using preshared).
11-03-2008 07:12 AM
The setting I had mentioned is only for a particular L2L IPSEC tunnel.
11-03-2008 10:48 AM
Fadi,
Are you using Pre-Shared Keys or Certificates for Authentication. Please refer the below link for information on VPN Client AM and MM.
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_data_sheet090
0aecd801a9de9.html
Aggressive Mode is the default and the only mode available for Pre-shared key and Main Mode is only available for the Cert authentication.
So, it is my understanding that it is not possible for VPN clients to use main mode to authenticate to the VPN3000 with pre-shared keys.
Arul
*Pls rate if it helps*
