Block Connected Party ID update on H323 gateway
Nov 3rd, 2008
I have an IOS H323 gateway in between a CallManager 6.1 and a PBX with a H323 / IP card in it.
When I make a call to a PBX extension, the PBX updates the CallManager with the Connected Party ID.
Is there a way on the gateway to ignore this update from the PBX?
I did try restricting connected party id in the route patterns and translation patterns, but it does not seem to block the update.
Cheers,
Tim.
Overall Rating: 5 (1 ratings)
MARTIN STREULE Mon, 11/03/2008 - 05:20
This will help:
voice service voip
no supplementary-service h225-notify cid-update
Cheers,
Martin
Tim Smith Wed, 11/05/2008 - 13:20
Thanks.. that is perfect.
Will try it out and see if it does the trick.
Cheers,
Tim.
