Route tag question
Answered Question
Nov 3rd, 2008
What does the following tag do:
ip route 0.0.0.0 0.0.0.0 10.142.104.244 tag 41
1. When and why we need a tag?
2. when we need to set tag under route-map statement?
I will appreciate if anyone can send me a document link about tagging.
Thanks in advance,
Overall Rating: 5 (1 ratings)
guruprasadr Mon, 11/03/2008 - 04:44
  • Gold, 750 points or more
HI Chowdhury, [Pls Rate if HELPS]
To redistribute routes in the routing table that match the specified tags, use the match tag command in route-map configuration mode. To remove the tag entry, use the no form of this command.
Examples
The following example redistributes routes stored in the routing table with tag 5:
route-map name
match tag 5
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
