Unable to handle 64-bit address space
MDS 9216i keeps rebooting and getting the following message:
Starting kernel...
PCI: Unable to handle 64-bit address space for
PCI: Cannot allocate resource region 7 of bridge 02:01.0
PCI: Cannot allocate resource region 0 of device 02:01.0
PCI: Error while updating region
PCI: Failed to allocate resource
Any suggestion..?
ebreniz Fri, 11/07/2008 - 12:29
  • Silver, 250 points or more
Try the bug id CSCsi86627... says PCI Unable to handle 64-bit address space for
Michael Brown Mon, 11/10/2008 - 10:53
  • Cisco Employee,
I don't believe that CDETs is open against the 9216. If you are seeing this error occur on the MDS console, then I suspect a hardware error on the 9216. Software failures would land you at a BIOS prompt, or at a 'LOADER>' prompt. I suggest you contact your 9216 hardware service provider.
Trending Topics: Storage Networking
