pklos Mon, 11/03/2008 - 07:07
  • Silver, 250 points or more
If you want to get presence status from CUPS you should use SIP protocol. SOAP is just for configuration.
regards,
PK
sanoopdamodaran Mon, 11/03/2008 - 21:00
Please help me to get some samples to use SIP protocol for getting the presence status.
sanoopdamodaran Tue, 11/04/2008 - 22:19
i've gone through the document and i'm able to send SOAP request to CUPS using C#. But i'm not sure how to use SIMPLE in C#. following is the code i've used to send SOAP request to CUPS
using System;
using System.Xml;
using System.Text;
using System.IO;
using System.Net;
using System.Security.Cryptography.X509Certificates;
public class WebServiceAccess
public WebServiceAccess()
string xmlfile;
xmlfile="<?xml version=\"1.0\" encoding=\"UTF-8\"?>" +
"http://www.w3.org/2003/05/soap-envelope\" xmlns:SOAP-ENC=\"http://www.w3.org/2003/05/soap-encoding\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" xmlns:pr=\"urn:cisco:epas:presence:rules\" xmlns:epas=\"urn:cisco:epas:soap\">" +
" cdickens " +
" 123456 " +
HttpSOAPRequest(xmlfile,null);
public void HttpSOAPRequest(String xmlfile, string proxy)
byte[] bytes = null;
System.Net.ServicePointManager.ServerCertificateValidationCallback +=
delegate(object sender, System.Security.Cryptography.X509Certificates.X509Certificate certificate,
System.Security.Cryptography.X509Certificates.X509Chain chain,
System.Net.Security.SslPolicyErrors sslPolicyErrors)
return true;
HttpWebRequest req = (HttpWebRequest)WebRequest.Create("https://10.75.1.60:8443/EPASSoap/service");
req.Headers.Add("SOAPAction","\"\"");
req.ContentType = "text/xml;charset=\"utf-8\"";
req.Accept = "text/xml";
req.Method = "find_business";
// Add the network credentials to the request.
Console.WriteLine("Step 1");
// Encode the body using UTF-8.
bytes = Encoding.UTF8.GetBytes((string)xmlfile);
// Set the content header length. This must be
// done before writing data to the request stream.
req.ContentLength = bytes.Length;
Stream stm = req.GetRequestStream();
// Write the SQL query to the request stream.
stm.Write(bytes, 0, bytes.Length);
Console.WriteLine("Step 2");
stm.Close();
WebResponse resp= (HttpWebResponse)req.GetResponse();
Console.WriteLine("Step 3");
stm = resp.GetResponseStream();
StreamReader r = new StreamReader(stm);
// process SOAP return doc here. For now, we'll just send the XML out to the browser ...
Console.WriteLine(r.ReadToEnd());
Console.WriteLine("Step 4");
public static void Main(string[] args)
new WebServiceAccess();
This code is working fine. Sameway how do we send request for getting the user availability? Please help me to get some samples on this.
pklos Wed, 11/05/2008 - 06:52
You need to use SIP (SIMPLE) and subscribe contact:
http://www.cisco.com/en/US/docs/voice_ip_comm/cups/6_0_1/interoperability/developer/guide/cpsinter.html#wp36696
During subscription CUPS server will send you information about yours contact presence on every change.
If you have no idea about SIP+c# look here:
http://www.codeproject.com/KB/cs/SIP_stack_with_SIP_proxy.aspx
regards,
PK
sanoopdamodaran Thu, 11/13/2008 - 05:12
Hi again..i could not get what to enter in the application.. like settings/Registrations/gateway etc.. Please help me out to find some simple examples..
From CUAD, i need to access the CUPS and find out the status..there is an example in cisco wiki call presenceMonitor..but its not working for me..
