VPN - Lost Packets
Nov 3rd, 2008
I have a Cisco 2621XM router setup running IOS 12.4(21a), which provides internet connectivity via an ADSL line. The router also has several site to site VPN's and GRE/IPSec tunnels. Connectivity to the sites via the GRE/IPSEC tunnels work without a problem as does internet connectivity.
The site to site IPsec tunnels (non-GRE) to other client sites currently display th following: the VPN tunnels come up and pass traffic, however, there seems to be pqacket loss. If I open a ping to a remote host I get reply, request timed out, reply etc. Also, RDP failes to work altogether and SSH is extremely slow.
A constant ping to http://www.google.com or to a host over the GRE/IPsec tunnel is constant and works fine. I have tried a different router in it's place and get the same issue.
Any help with this would be greatly appreciated.
Below is the config:
version 12.4
service password-encryption
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip dhcp use vrf connected
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp policy 20
encr 3des
group 2
crypto isakmp key sitea address x.x.x.x
crypto isakmp key siteb address x.x.x.x
crypto isakmp key sitec address x.x.x.x
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode transport
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
mode transport
crypto map crypto_map 10 ipsec-isakmp
set peer x.x.x.x
set transform-set ESP-3DES-SHA
set pfs group2
match address acl_gre_traffic_n1
crypto map crypto_map 20 ipsec-isakmp
set peer x.x.x.x
set pfs group2
match address acl_gre_traffic_n2
crypto map crypto_map 30 ipsec-isakmp
set peer x.x.x.x
match address acl_crypto_map30
crypto map crypto_map 40 ipsec-isakmp
set peer x.x.x.x
match address acl_crypto_map40
crypto map crypto_map 50 ipsec-isakmp
set peer x.x.x.x
set transform-set ESP-3DES-MD5
match address acl_crypto_map50
interface Tunnel0
ip address 192.168.100.1 255.255.255.252
ip nat inside
ip virtual-reassembly
keepalive 10 3
tunnel source FastEthernet0/0
tunnel destination x.x.x.x
interface Tunnel1
ip address 192.168.200.1 255.255.255.252
ip nat inside
keepalive 10 3
interface FastEthernet0/0
description Outside Interface
ip address x.x.x.x 255.255.255.248
ip nat outside
duplex auto
speed 100
interface Serial0/0
no ip address
shutdown
no fair-queue
interface FastEthernet0/1
description Inside Interface
ip address x.x.x.x 255.255.255.0
ip nat inside
duplex auto
speed auto
ip nat pool crypto_map30_pool x.x.x.x x.x.x.x netmask 255.255.255.0
ip nat pool crypto_map40_pool x.x.x.x x.x.x.x netmask 255.255.255.192
ip nat inside source route-map route_map_nat interface FastEthernet0/0 overload
ip nat inside source route-map route_map_crypto_map30 pool crypto_map30_pool
ip nat inside source route-map route_map_crypto_map40 pool crypto_map40_pool
ip dns server
route-map route_map_nat permit 1
match ip address acl_nat
route-map route_map_crypto_map40 permit 1
match ip address acl_crypto_map40_nat
route-map route_map_crypto_map30 permit 1
match ip address acl_crypto_map30_nat
alraycisco Tue, 11/04/2008 - 06:44
Thanks for the reply. Strangely the VPN tunnels that terminate off the Tunnel interfaces don't have a problem, it's just the non-GRE IPSEC tunnels. I've tried adjusting the mtu sizes on the physical outside interface using the above commands, however, I still have the same problem.
I've also tried using the 'mtu 1400' command on the physical interface, however I get:
% Interface FastEthernet0/0 does not support user settable mtu.
alraycisco Tue, 11/04/2008 - 07:28
Once again thanks for the response. I have tried the above, however, I am still experiencing the same problem, having brought the VPN tunnels down.
According to the site pre-fragmentation should be on by default.
alraycisco Mon, 11/10/2008 - 05:44
Just an update on this, as a test I've setup an additional IPsec tunnel to an ASA5505 (my home ASA). Connectivity over this VPN works without any problems.
I find it quite strange that 3 customer VPN's should display the same problems (dropped packets), yet an IPSec VPN to my home firewall works without any problems. Is there anything I can get the customer to do at their end? Is the problem that their MTU values are considerably lower than my outside interface's MTU?
