Purge Management Issue in LMS 3.1 .
Nov 3rd, 2008
Hi ,
We have configurted the purge setting as
Maximum version to retain : 10
Purge version older than : 30 days
in LMS 3.1 .
But while we are viewing the Version tree in the arecheve management we are getting around 30 numbers of running and startup instead of 10 .
But this issue is not there for all devices .
So please suggest how do we maintain this number as 10 .
Regards ,
sinjish.K
Joe Clarke Mon, 11/03/2008 - 14:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Make sure you are also doing ChangeAudit purging, retaining a similar amount of data. ChangeAudit purging is configured under RME > Admin > Change Audit > Set Purge Policy.
k_sinjish Mon, 11/03/2008 - 22:06
Hi ,
Thanks for your update . We have set the purge policy also to 30 days now . But we could not see any change in the same .
Can you please suggest how do we proceed with the same .
Regards ,
sinjish.K
Joe Clarke Mon, 11/03/2008 - 22:16
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Make sure the Change Audit purge has run by going to Force Purge. Then wait for the config purge job to run again.
k_sinjish Mon, 11/03/2008 - 22:35
We have done Force purge and run type as immediatly .Still puging is in the same way . We have seen the RME job as success in Job management also .
Regards ,
Sinjish.K
Joe Clarke Wed, 11/05/2008 - 10:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Enable Config Job debugging under RME > Admin > System Preferences > Application Loglevel Settings, then run another purge job. Post the log from the job directory.
