Check other CSQ before transferring call
Nov 3rd, 2008
Hi, I would like to know if this is possible and if someone has a sample on how to accomplish this.
I would like to do the following:
If a customer is waiting on a queue for more than 5 mins to transfer the call to a different queue if only the other queues have Agents on Ready Status. I would like the script to check the other queues for Agents Ready first before it transfers the call to that queue. Hope someone can help me, thanks.
Overall Rating: 5 (2 ratings)
Chris Deren Mon, 11/03/2008 - 09:38
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Sure you can do this, simply use the Get Reporting Statistics step and check the "Ready Resources" object, store it as a local variable and perform IF statement to check if it's larger than 0, if so select that CSQ otherwise do whatver else you want with the call.
HTH,
Chris
danymora17 Mon, 11/03/2008 - 12:32
Do you have an example? I am trying how to get the variable to look into CSQ2 and not the current CSQ1 it is on.
Chris Deren Mon, 11/03/2008 - 13:06
  • Hall of Fame,
Under "Row Identifier" select the CSQ value of CSQ2 not CSQ1.
Chris
danymora17 Tue, 11/04/2008 - 11:23
I only have CSQ value and my other contact queues do not appear, how do I tell which CSQ it is looking at? Sorry I am new at scripting. Thanks for your help.
Chris Deren Tue, 11/04/2008 - 11:28
  • Hall of Fame,
OK, here is what to do in your script:
define varaibles:
string: CSQ1 == "name of the inital CSQ"
string: CSQ2 == "name of the second CSQ"
integer: intAgentsReady == 0
select resource (CSQ1)
queue
get reporting statistic (CSQ2, resrouces ready, intAgentsReady)
if intAgentsReady > 0
true
dequeue CSQ1
select resrouce (CSQ2)
false
HTH,
Chris
danymora17 Tue, 11/04/2008 - 12:29
Thanks Chris, I think I got it. Now one more question please. I first want to check if the customer has been on hold for atleast 5 mins before i check the other CSQ, How would I define the variable to check if the customer has been on hold for atleast 5 mins?
Chris Deren Tue, 11/04/2008 - 12:33
  • Hall of Fame,
danymora17 Tue, 11/04/2008 - 13:16
I think I got it, now when I select the Resource for CSQ2 i have the following
contact -> trigger contact
Routing TargetType -> Contact Service Que
CSQ Target -> CSQ2
Connect -> no
Timeout -> 12
resource selected -> _TmpRsrc1163171232265
Now the resource selected is the same as CSQ1, does that matter? Thanks Chris
Chris Deren Tue, 11/04/2008 - 13:17
  • Hall of Fame,
no.
Chris
