Blocking incoming calls
I need to block an incoming caller with a specific Caller ID. I have seen the articles referring to using the "voice translation-rule" command. I am not able to run this command using IOS version 12.2.46a on my H.323 voice gateway.
Does anyone know the IOS version and feature set required to use "voice translation-rule"
Chris Deren Tue, 11/04/2008 - 06:49
12.2? First I would recommand going to later version of IOS especially if you are running voice on this router. My recommandation would be 12.4.7h or 12.4.15T4.
