CiscoView 7200 support
Answered Question
Nov 3rd, 2008
I just installed the latest package for the 7200XVR and the NPE-G1 still shows up on both the front and back views, this isnt correct, it should only show up on the front view - I believe. Is this correct?
Correct Answer by Joe Clarke about 8 years 8 months ago
This is bug CSCsh62557 which is fixed in Rtr7000 package 21.2. A patch is available if you contact the TAC.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 11/03/2008 - 10:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
sirbaughmf Thu, 11/06/2008 - 06:35
I installed 21.2 but that didn't seem to fix the issue, the NPE-1 still shows on the front and rear of the device??????
Joe Clarke Thu, 11/06/2008 - 07:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The bug states that the CiscoView patch tried to work around some issues with the SNMP agent. Whenever this approach is taken, things don't always work out the way they are supposed to. There may some other agent issues present which the patch did not handle.
Since you already have a TAC service request open, work with your engineer to provide feedback to development. In particular, they will probably need to see a walk of the entPhysicalTable from this 7200.
