PM-SP-4-ERR_DISABLE: pagp-flap error detected on Gi3/26
jjpeyrache
hello
my customer got this error message time to time even if channel is configured under lacp instead pagp ??
where can i dig into , (configuration are ok on both side and error free on coutners)
12.2.18SXF4
any comments appreciated
JYP
Prashanth Krishnappa
I am suspecting the link to be flapping here. Can you configure "logging event link-status" under the interfaces?
Also, try following config commands and see if the problem persists ?
1) errdis recovery cause pagp-flap
2) errdis flap cause pagp max 10 time 30
5 Replies 5
hello
thanks for your reply
is it safe that you asked to do since
customer is in production ?
let me know
JYP
jjpeyrache
logging event link-status commands
is it supported in 12.2.18 ?
i looked on descriptions and see only on
12.2(25)SG
JYP
It is supported and an interface configuration. You can enable the command with no impact
jjpeyrache
thanks guy !
patch panel connector was defective on one port
JYP
