catalyst 6509 OS and FTp
Nov 3rd, 2008
I have a new software version on a laptop which I am going to apply to a catalyst 6509 with cat OS. I have the laptop connected to a switch and the switch connected to the cat6509. I want to use ftp to upgrade the software version on the cat6509. I keep getting the not connected message. I am able to ping everything. What is the procedure I should use to upgrade this 6509. Does the 6509 have a ftp server or client in it?
Richard Burts Mon, 11/03/2008 - 09:29
This shows that CatOS does support FTP.
cat6500> (enable) copy ?
acl-config Copy ACL configuration to a device
config Copy configuration to a device
flash Copy from flash
ftp Copy from FTP server
log-cmd Copy log command buffer to a device
rcp Copy from RCP server
scp Copy from SCP server
tftp Copy from TFTP server
File name
This is from a Cat6509 running 8.5(6) on the sup.
glen.grant Mon, 11/03/2008 - 16:41
That must have been an option in 8.x code , not available on the 7.6 code that we have so the box would have to have at least 8.x code to support ftp . Believe it started in 8.1 code.
sridsdale Mon, 11/03/2008 - 12:29
CatOS has an ftp client so you'll need an FTP server with the image on it.
set ftp username
Then enter:
set ftp password
This'll prompt you to enter the password for the user account you entered to use.
copy ftp flash
Just follow the instructions, you need to put in the address of the ftp server and the /path/to/filename to download.
