Phone Designer 7.0 on Call Manager 4.2
Answered Question
Nov 3rd, 2008
Does this work on CM4.2? It asks for CCMCIP Service which I don't have. Is there something I should put in there, or is there a different version that works with 4.2? Thank you.
Correct Answer by Tommer Catlin about 8 years 3 months ago
I dont think it does. Only works with 6.x and above. You can try, but I bet it will fail.
cheers
here is the link
http://www.cisco.com/en/US/docs/voice_ip_comm/cupa/phone_designer/7.0/english/release/PDReleaseNote70.html
Overall Rating: 5 (1 ratings)
Rob Huffman Mon, 11/03/2008 - 09:54
Hi Andrew,
This is only supported on CCM 6.x and 7.x;
Server and Client PC Requirements
Table 1-1 describes the server and client PC requirements for installing Phone Designer.
Server/Network
•Cisco Unified Communications Manager release 6.0, 6.11 and 7.0
-The Cisco Unified Communications Manager server must be installed, configured, and operating correctly as per the Cisco Unified Communications Manager documentation, at the following URL:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/tsd_products_support_series_home.html
-The Cisco Unified Communications Manager server must be configured to support the Phone Designer application.
Hope this helps!
Rob
