11-03-2008 10:46 AM
I started with LMS 2.2, then got an upgrade service release to 2.5 and later on upgraded to 2.6. Now, I have an service release to 3.0 and this can only be installed on top of LMS 2.6. However, my existing server is below the minimum hardware requirements therefore I want to install the 3.0 on a brand new server. What is the best way to do it?
My ciscoworks is installed on a Windows platform and the new server also has Windows OS.
Thanks in advance.
11-03-2008 10:52 AM
Simply install 3.0 on the new server from the 3.0 DVD. If you want to migrate the data from your current server, see http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.0/data_migration/guide/dmg_win.html#wp1134820 to perform a remote data migration.
11-04-2008 07:57 AM
Then I'm good to go. Thanks for the quick reply.
