11-03-2008 12:29 PM - edited 03-06-2019 02:17 AM
Looks like yet another example of mysteriously disappearing features... We have a couple of 28x1's, we have recently upgraded IOS from 12.4(3d) to 12.4(21) on some of them due to a couple of issues, and suddenly I can see:
rtr-site1#show access-lists compiled
Compiled ACLs unavailable
- and the router stopped recognizing the "access-list compiled" directive.
Now when I look at IOS reference, I see that it lists Turbo ACLs as "available on Cisco 7200, 7500 and 12000".
I tried different 12.4(21) feature sets, but still not available - while working fine on 12.4(3d).
Is there a reasonable explanation for this other than a marketing move - the likes of "iPhone VPN is only supported on Cisco PIX and ASA"?
11-03-2008 04:29 PM
Yup, it was deactivated in the later releases. Wasn't supposted to be there; unsupported. It might not function correctly. (As told by TAC.)
PS:
Seemed to work alright in the releases it was active in (up through 12.4[12]?), but it does seem likely a marketing decision. Makes the low end ISRs too feature like the higher end models.
11-04-2008 09:29 AM
- so that you're even more likely to consider buying a higher spec router when yours is starting to struggle with matching... Oh well.
Wojciech
11-04-2008 09:38 AM
Perhaps, but you can still carefully sequence ACL entries (based on the hit frequencies, and if sequence logic permits). You can also activate flow cache, which I believe no longer requires a separate feature license. Either or both can help mitigate the lost of the ACL compiled feature.
