C6509: CatOS -> IOS
Nov 3rd, 2008
Sup720-3B
I'm converting a 6500 switch from CatOS to IOS. Attached is the 'sh mod' from the 6500. Will I need to upgrade the rommon for the ios upgrade?
Below are the guides I will be using for the upgrade.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml#conv_720
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a0080816fbc.shtml
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Mon, 11/03/2008 - 13:47
  • Hall of Fame,
    Founding Member
Hello Colm,
about the second guide the usage of this conversion tool is not recommended in other threads.
A manual conversion of the catOS configuration file is to be preferred.
your FW and SW versions on slot 5 supervisor are:
8.1(3) 8.5(3)
the first document refers to the release notes of CatOS that says:
For Supervisor Engine 720, the minimum boot ROM required for software release 8.1(1) and later releases is 7.7(1)
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/release/notes/OL_4498.html#wp548611
So my understanding is that you shouldn't need to upgrade the rommon firmware on the supervisor
Hope to help
Giuseppe
colmgrier Mon, 11/03/2008 - 15:16
Thanks a million Giuseppe for the information.
