Reassembly limit exceeded
Nov 3rd, 2008
After upgrading a PIX 515 of ours from 7.2 to 8.0 an issue was discovered where large SQL transfers were being dropped.
Troubleshooting the issue I discovered errors in the logs reporting connections on port 1521 (SQLNET) between the servers in question saying "reassembly limit of 8192bytes exceeded"
I found this page relating to the error:
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807c35e7.shtml
And so I disabled SQLNET inspection by using:
policy-map global_policy
class inspection_default
no inspect sqlnet
This corrected the issue however I don't think this is ideal.
Also after doing a line-diff comparison of the config prior to upgrade I realised that SQLNET was being inspected before, so the upgrade has somehow changed something there.
Any ideas?
sadbulali Fri, 11/07/2008 - 13:07
  • Bronze, 100 points or more
Explanation: This message displays when the reassembly buffer limit is exceeded during assembling TCP segments.
source_address/source_port - The source IP address and the source port of the packet initiating the connection.
dest_address/dest_port - The destination IP address and the destination port of the packet initiating the connection.
interface_inside - The name of the interface on which the packet which initiated the connection arrives.
interface_outside - The name of the interface on which the packet which initiated the connection exits.
limit - The configured embryonic connection limit for the traffic class.
The resolution for this issue is to disable the RTSP inspection in the security appliance as shown.
inspect dns migrated_dns_map_1
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
no inspect rtsp
