Giuseppe Larosa Tue, 11/04/2008 - 00:30
Hello Arum,
%Error opening tftp://192.168.170.222/c2801-adventerprisek9-mz.124-20.T.bin (Timed out)
*Nov 4 08:22:39.503: UDP src=50655, dst=69, Stateful Inspection(19), rtype 2, forus FALSE, sendself FALSE, mtu 0
disable ip inspect command and retry:
probably you have not configured UDP handling.
It is faster to remove CBAC copy the new image and then reapply ip inspect
Hope to help
Giuseppe
arumugasamy Wed, 11/05/2008 - 22:09
Dear,
I completely removed the cbac and tested.One thing to remember is the flash space in very less than the original image to be copied to the flash.
I used the solarwind tftp.
Let me try with tftp32d.
