Gateway configuration in cisco callmanager 4.1.3
Nov 4th, 2008
i configured the gateway in the ccm,and now i want to configure route pattern but when im configuring it i can see anything in the gateway or route list to select,so im stuck there i can continue anybody can help please.
Overall Rating: 5 (1 ratings)
allan.thomas Tue, 11/04/2008 - 02:18
  • Blue, 1500 points or more
If the gateway is included in a Route Group the drop-down list box does not display the the individual gateway.
The gateway will also not apppear if you have already assigned the gateway to a route-group, but you have not assigned the route-group to a route-list.
If you have created a gateway, it should appear in the drop box, unless of course you have assigned it to a route-group already.
Similarly if you have assigned a gateway to a route-pattern, then you will not be able to add that same gateway to a route-group. Unless you delete the route-pattern first.
Allan.
