private FXO line
Nov 4th, 2008
Hi expert,
i have CME where PRI and 1 FXO line is terminated, i want to make FXO line as a private line for one xtension let say 606, i configured it and it was wroking fine but i want to use this line only for international dialing and local and national calls should go thru PRI
ephone-dn 1
number 606
trunk 82
voice-port 0/1/0
connection plar opx 606
dial-peer voice 1 pots
destination-pattern 82
Port 0/1/0
i llappreciate if somebody suggest any solution
allan.thomas Tue, 11/04/2008 - 02:44
  • Blue, 1500 points or more
You can specify the trunk directly on the ephone-dn which is specifically tied to a pots dial-peer. Simply configure your digit length on the dial-peer after the trunk access.
ephone-dn 1
trunk 82
dial-peer voice 10 pots
destination-pattern ^82....T
port x/y
Allan.
zahid77 Tue, 11/04/2008 - 02:56
i have done this config but if i want to use PRI line then what shuld i do i have already madde so many dial-peers for COR list where normal users are making calls as per their privilages
now this particular port should be used as private line as well as this users should ve a access to PRI line as well
please suggest
allan.thomas Tue, 11/04/2008 - 03:49
The only solution around this would be to configure translation rules, which translates the called number using a prefix or recognises an international call and then adds the 82 prefix.
The call will route out of the appropriate outgoing port base on the prefix dialled by the private line user.
voice translation-rule 1
rule 1 /^900/ /8200/
rule 2 /^9/ /9/
voice translation-profile User1
translate called 1
ephone-dn-template 1
translation-profile outgoing User1
ephone-dn 1
number 606
destination-pattern 82T
port 0/1/0
I have assumed that you are using 9 outside line, so the translation depends on how your PRI dial-peers are configured.
In this example if extension 606 dialled an International call starting 900, it will be translated to 82 and therefore match the outgoing dial-peer 1.
Every other call starting with 9 made from extension 606 will be routed with only 9 as the prefix and should therefore match your other dial-peers.
Allan.
zahid77 Tue, 11/04/2008 - 04:29
thanks then let me try this solution i ll update tomorrow morning
zahid77 Wed, 11/05/2008 - 02:21
ok i applied the solution find my config below
voice translation-rule 82
rule 2 /^9/ /9/
voice translation-profile User606
translate called 82
translation-profile outgoing User606
ephone-dn 64 dual-line
number 606
pickup-group 123
label MANAGER
name manager
corlist incoming call-International
corlist outgoing call-International
dial-peer voice 204 pots
port 0/1/0
after applying this configuration i am getting cointinous tone
please suggest
allan.thomas Wed, 11/05/2008 - 02:30
When you dial an international call 900.... from extension 606 can you enable 'debug voice ccapi inout'.
This will determine which dial-peer is used, and what the expected ani and called number is.
Have you tried a test call with the corlists on the ephone-dn?
Can you post the reset of your configuration, so that we can see your other dial-peers and how they are configured. This is incase there are overlapping ones.
Allan.
allan.thomas Wed, 11/05/2008 - 04:07
The debugs indicate that the correct outgoing dial-peer is selected, however the called number is only 82?
What number is being dialled exactly from extension 606, it should be 900........ in order to match the appropriate translation-rule.
What I neglected to ask is whether 82 should be dropped from the outgoing call? Otherwise the call will routed as 00....... which is what I would ordinarily expect.
Allan.
zahid77 Wed, 11/05/2008 - 04:20
yes after applying tis config, i dialed 900......... or any international complete number like 900923214001096
but the continous ring is coming even when i dial any national number
i saw in the debig that it is not forwarding in digit at destination
allan.thomas Wed, 11/05/2008 - 04:44
Although I cannot see what this would affect the behaviour, try changing the voice translation rule to be more specific. Both ways achieve the same net result.
rule 1 /^900\(.+\)/ /8200\1/
rule 2 /^9\(.+\)/ /9\1/
Allan.
allan.thomas Wed, 11/05/2008 - 08:07
Hi Zahid, I believe the issue is that the translation-profile should be applied to the incoming call-leg on the ephone-dn-template and not the outgoing.
no translation-profile outgoing User606
translation-profile incoming User606
When the translation profile was applied to the outgoing call-leg I received fast-busy as soon as 9 was dialled.
When applied to the inbound call-leg I was able to dial the full number.
I have tested this using a VoIP dial-peer with a destination-pattern 82T and the following setup:-
voice translation-rule 6
voice translation-profile Test
translate called 6
dial-peer voice 1001 voip
session target ipv4:192.168.0.6
translation-profile incoming Test
ephone-dn 1
number 1003
Below is the debug, you will see that called number is 8200123456789, this is because it is a VoIP dial-peer, 82 will be stripped by the POTs dial-peer in your case:-
In: Calling Number=1003(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pre
sentation=Allowed)
*Mar 2 08:18:01.195: //15/CF850FFE8034/CCAPI/ccCheckClipClir:
Out: Calling Number=1003(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pr
esentation=Allowed)
*Mar 2 08:18:01.195: //15/CF850FFE8034/CCAPI/ccCallSetupRequest:
Destination Pattern=82T, Called Number=8200123456789, Digit Strip=FALSE
Calling Number=1003(TON=Unknown, NPI=Unknown, Screening=Not Screened, Present
ation=Allowed),
Called Number=8200123456789(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=
Account Number=, Final Destination Flag=FALSE,
Guid=CF850FFE-2CEC-11D6-8034-C987658569E3, Outgoing Dial-peer=1001
*Mar 2 08:18:01.195: //15/CF850FFE8034/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=1003
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=8200123456789
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*Mar 2 08:18:01.195: //15/CF850FFE8034/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x66B8BB40, Interface Type=1, Destination=, Mode=0x0,
Call Params(Calling Number=1003,(Calling Name=)(TON=Unknown, NPI=Unknown, Scr
eening=Not Screened, Presentation=Allowed),
Called Number=8200123456789(TON=Unknown, NPI=Unknown), Calling Translated=FAL
SE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-pe
er=1001, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl
ication Call Id=)
*Mar 2 08:18:01.195: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar 2 08:18:01.195: :cc_get_feature_vsa malloc success
*Mar 2 08:18:01.195: cc_get_feature_vsa count is 2
*Mar 2 08:18:01.195: :FEATURE_VSA attributes are: feature_name:0,fearture_time:
1724962032,feature_id:16
*Mar 2 08:18:01.199: //16/CF850FFE8034/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Allan
zahid77 Wed, 11/05/2008 - 08:18
Thanks a lot Allan
i l try it tomorrow morning
i think this ll help me a lt
i really appreciate your time and effort to help me
God bless you
Zahid fayyaz
zahid77 Wed, 11/05/2008 - 08:22
sorry Allan again
now i have additionally create a VOIP dial peer with 82T destination pattern
then what about my POTS dial-peer
it seems my config will like that
translate called 6
dial-peer voice 1002 pots
detsination-pattern 82T
port 0/1/0
ephone-dn 1
number 1003
trunk 82
allan.thomas Wed, 11/05/2008 - 08:54
Hi Zahid, you do not need to add additional dial-peers, the voip dial-peer I referred to was to simply test the concept of the translation-profile.
You will only need to change the ephone-dn-template translation-profile to incoming. I also noticed that trunk 82 is under the ephone-dn, this is not need as we are using translations.
Below is the config that you need:-
translate called 82
incoming called-number .
port 0/1/0
number 606
pickup-group 123
label MANAGER
name manager
no trunk 82
Essentially, when extension 606 dials 900...... it will be translated to 8200..... and then match the outbound dial-peer 204 and route the call out of port 0/1/0. 82 will be stripped leaving 00...... as the called number, this is the nature of POTs dial-peers.
When 606 dials 90123456789 or 9123456 for example it will remain unchanged, and therefore match one of your PRI outbound dial-peers for national, local calls etc.
Allan.
zahid77 Wed, 11/05/2008 - 09:00
great Allan
but last confusion if i dont create trunk 82 even then this will be remain Private line for number 606
and nobody can use this FXO line except 606
i ll make these changes tomorrow morning
thanks again
allan.thomas Wed, 11/05/2008 - 09:15
For all intense purposes 82 should remain transparent to all users, unless they become aware of it and dial the number directly with 82.......
Only International calls made by extension 606 starting 900 will be translated transparently to the user and use 82.
If this access number becomes common knowledge, then simply change the translation pattern rule to use another number and change the POTs dial-peer pattern:-
For example, use 55:-
rule 1 /^900\(.+\)/ /5500\1/
translate called 82 (this doesn't change)
destination-pattern 55T
Allan.
zahid77 Wed, 11/05/2008 - 09:42
ok thanks
but there is no such solution vailable by we can restrict a particular line to particular extension
becuase i saw that solution where u just need to define trunk number under the ephone-dn
actually i tested that solution but after applying that line can only be restricted to that particular FXO port
anyways that solution is already working fine
i tested with diferent access code and translation rule
anyhow you really put a laot of effort to help me
it was a agreat experince to share with you
i ll get in touch with you
thanks
take care
