Jaime Valencia Tue, 11/04/2008 - 04:30
  • Cisco Employee,
  • Hall of Fame,
    2011
limitation should be around 500 per user
consider each entry per user consumes HDD space so it could bring trouble if you try to use all PAB entries with thousands of users
java
if this helps, please rate
hannyong Tue, 11/04/2008 - 08:13
Hi Java,
Any documentation which shows the figure 500?
Jaime Valencia Tue, 11/04/2008 - 08:16
  • Cisco Employee,
  • Hall of Fame,
    2011
no, BU info
java
