11-04-2008 03:08 AM - edited 03-14-2019 03:10 AM
Is it possible to setup the recording of all contact centre calls using the Premium edition?
For compliance reasons - I need to have everything recorded and I'd like to know if I can do this out of the box or if I need a seperate app to do this.
Dave
Solved! Go to Solution.
11-04-2008 04:36 AM
No. You will have to go to some 3rd party software like BluePumpkin, Verint, Nice, etc. UCCX records on demand only.
david
11-04-2008 04:36 AM
david
11-04-2008 07:46 AM
You "can" but you have to be careful on sizing. How many agents does your system have and what server type do you have? Attached is how to setup a workflow to record all calls. To save them longer than 30 days, you will have to copy the files to another server or directory on another server.
Its not as elegant of a solution as the 3rd party options David referred to, but an option none the less.
please rate helpful posts.
- Andy
11-04-2008 10:15 AM
Thanks Andy. It's good to have options.
11-04-2008 10:56 AM
Sorry forgot to answer the questions!!
It will be for 20 - 25 agents and we'll be using 7825 - H3 boxes. I don't imagine a particularly large number of calls coming in but it's a financial institute so they all need recording.
Cheers
Dave
