MOH issue CUCM6.0.1 G729
Nov 4th, 2008
On a 3 CUCM cluster, 3 MOH servers, the wave file has been uploaded on the 3 servers.
Using G729 over the WAN, I can notice that messages in the music are troncated, the same words are missing on the 3 servers. On 4.x I never noticed that.
Jaime Valencia Tue, 11/04/2008 - 04:11
  • Cisco Employee,
  • Hall of Fame,
    2011
do you have QoS in place??
java
if this helps, please rate
guy.richard Tue, 11/04/2008 - 05:05
Yes and I have created a new "region" on the HQ site to be able to choose G729 codec and I've the same issue of troncated MOH and I can hear that it is always the same sample missing.
Jaime Valencia Tue, 11/04/2008 - 05:09
  • Cisco Employee,
  • Hall of Fame,
    2011
if you configure a local phone to hear that stream does the same happen?? if so, i would think the stream is the one corrupted
java
guy.richard Tue, 11/04/2008 - 05:33
yes it is a local phone, same switch as CUCM, just a different region to force codec and it is the same on the 3 MOH server.
We have another end customer, same version 6.0.1.2000-4 with 2 7825: same issue even with the default MOH (Cisco CD), if you listen to the MOH with 2 phones one in G711 the oter in G729, you can hear the message is shortened 2 or 3 sec every 10or 15 sec.
I did never seen (or heard) that on vers4.x
