Switch 2950 boot problem
Nov 4th, 2008
The switch boots up immediately into Rommon mode. The flash system is empty. Is there a way to copy a new ios into the flash file system?
Thanks for any pointer
Jon Marshall Tue, 11/04/2008 - 03:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You will need to use xmodem to transfer a new IOS onto the 2950. Attached is a link to recovering software on 2950 switches -
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_20_ea2/configuration/guide/swtrbl.html#wp1021167
Make sure you set BAUD rate to 115200 as that will speed things up a bit :-)
Jon
