Barcode Scanners
Nov 4th, 2008
Hi all,
We are looking to scan in MAC address' via the barcode on the box.
Is there a certain sort of barcode reader we need to purchase?
Can anyone recommend one?
Thanks in advance for any help
Rob Huffman Tue, 11/04/2008 - 05:29
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jamie,
This tool is a definite must that's for sure :)
We use the Symbol LS2208 shown @ the link below. This has worked very well for us :)
http://www.barcodestore.co.uk/product.asp?s=5gzgld190391&strParents=&CAT_ID=0&P_ID=166
There are also many others listed in this good link from "The Kid";
http://www.barcodestore.co.uk/Barcode-Scanners--Readers-/Best-Selling-Barcode-Scanners--Readers/Decode-X9000/p-70-132-252/#
Hope this helps!
Rob
Rafael Chavantes Tue, 05/31/2011 - 10:27
Hello Rob,
I now I'm reviving this topic from several years ago, but I would like to know, if with this barcode scanner you need anything else?
You just scan the barcode and the information goes to excel?
It is a USB right?
Rafael
Aaron Harrison Wed, 01/16/2013 - 11:36
  • Community Spotlight Award,
    Member's Choice, May 2015
I picked up a high quality (ahem) scanner from ebay for about £7, shipped from Hong Kong to the UK... and it worked fine.
I think the encoding is pretty standard.. at least more 'standard' than H323 or SIP :-)
