Nov 4th, 2008
Is there a possibility to read the firewall configuration over snmp and write it down to a tftp server? The customer has two firewallsystems and want to save the configurations daily to a tftp server. He has a linux server to provide the snmp and tftp services. The CSM is too big for this really little problem. For routers and switches exist a solution, named pancho.
cisco24x7 Tue, 11/04/2008 - 06:05
You need to put on the security hat for this.
TFTP is NOT secure. Furthermore, SNMP can not
what you want.
Why not use RANCID to do this? It is secure
and can be done over SSH
maik.behley Thu, 11/06/2008 - 04:53
Thanks, this can be the right solution. I have tested this tool. The first device is polled and i get the config. But the config from the second device i can't get. The server has the ssh right's and the correct password. In the config directory the rancid process create the file but this file has 0 byte. Can you help me?
In the logfile i see the following failure:
IP_ADDRESS clogin error: Error: TIMEOUT reached
IP_ADDRESS missed cmd(s):
Do you have any idea?
cisco24x7 Thu, 11/06/2008 - 05:21
I have to disagree with you on this. Why
pay for something when you can get it for FREE?
RANCID is the best tool, bar NONE. It can even
backup Unix DNS, sendmail configuration and
Checkpoint Secureplatform firewalls. You can
backup >1000 devices with RANCID on either
gentoo or redhat linux box. A very scale
Can Device expert do that?
