VIP in SLB can not connect to the real servers
Nov 4th, 2008
Hi!
I have this situation.
Three server farm, each with two real server, which should be accessed by their Virtual IP addresses in their respective ports, i.e. client request should be natted by the SLB to correspond to the real servers. This means that, clients are in different VLANs from the one with real servers. So clients connects by using Virtual IP addresses, and expected to be natted to the real one. Below is the sample of my configurations;
Server Farm Configurations
ip slb serverfarm SF_1
nat server
access Vlan21
real 10.152.1.69
weight 1
faildetect numconns 1 numclients 1
inservice
real 10.152.1.70
weight 1
inservice
Virtual Server Configurations
ip slb vserver VS_TCP1
virtual 10.154.0.47 udp 69
serverfarm SF_1
access Vlan1
replicate casa 10.200.0.13 10.200.0.14 1026 password xxx
inservice standby FW_Side
Now with this configuration, i need to achieve two things;
1. The virtual server needs to be configured to connect to the couple of ports with only one Virtual IP address.
2.The clients, who are in VLAN one, should use the virtual IP address, i.e. 10.154.0.47, to connect to the real servers in ports 20/21, 25 and 69 and any other specified after step one is configured for the couple of ports.
Any support, will highly be appreciated.
Willmark
Anonymous (not verified) Tue, 11/11/2008 - 15:28
The Cisco IOS Server Load Balancing (SLB) feature allows the user to define a virtual server that represents a cluster of real servers, known as a server farm. When a client initiates a connection to the virtual server, the Cisco IOS SLB load balances the connection to a chosen real server, which depends on the configured load-balance algorithm or predictor.
Configuring Real Servers and Server Farms:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA1_7_/configuration/slb/guide/rsfarms.html
