How to config CCM to implement blacklist
Nov 4th, 2008
i have ccm 4.1 and MGCP Voice gateway. so i can't config block profile command on my voice gateway. anyone have another method to implement blacklist?
Jaime Valencia Tue, 11/04/2008 - 06:13
  • Cisco Employee,
  • Hall of Fame,
    2011
CCM doesn't look at the calling number to determine routing or other process. you can only modify it (using masks)
unfortunately it's impossible to do it on CCM side.
it's H323 or nothing
many have tried, none have succeeded
java
if this helps, please rate
chenhao Wed, 11/05/2008 - 21:06
but can i have another method to implement the requirement, like programming use JTAPI ? or other? i'm software developer.
